Short throw shifter install
Old 11-28-2007, 09:06 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default Short throw shifter install
Article write up by Wildsurfer92!!!
Okay guys, I installed a hurst short throw in my car the other day, and i figured I would take some pics for everyone. Some of the things I did are not necessary such as removing the radio, or loosening the center console, but they made things easier and I wanted to check the condition of things. So here it is!
Stock Shifter and Hurst Shift stick and Top Plate
Pry up on the corner of the top plate with a flat head screwdriver to get it loose from the four clips that hold it in place
Pry up on the next corner
Pry up on the third corner
Slide the screwdriver down to make sure everything is loose
Pry up on the last corner
Remove shift **** by turning counter-clockwise
Shift **** removed and top plate loose
Pull up on top plate and slide it up and off the shift stick
Shifter with top plate and shift **** removed
Shifter Again
Begin removing 4 bolts holding lower shift boot in place
Removing bolt
Remove two bolts holding shift stick to shifter
Remove second bolt
Shifter Stick removed
Remove two screws holding center console down (phillips head)
Removing second screw
Remove 4 screws holding radio plate in place (phillip head)
Removing screw
Removing screw
Lower shift boot ready to be removed
Pull out lower shift boot
Stock Shifter with boot removed
Remove 4 bolts holding shifter down
Removing bolts
Grip Shifter and pull up to remove from transmission
Pull shifter up and into cabin of car
Transmission with shifter removed
Remove gasket material from mating surface
Had to use a screwdriver and some medical kelly clamps to get all the rtv out of the bolt holes
Clean gasket surface
Apply Black Rtv to mating surface
Place new shifter on transmission
Apply locktite to bolts
Locktite on bolt
Insert 4 bolts by hand
Tighten bolts
Tighten all 4 bolts
New Shifter tightened down
New Shifter
Adjust shift stops
Adjust second shift stop
Reinstall Shift boot
Reinstall Shifter Stick
Check Shifter Operation
Slide top plate over shift stick and down and press into place
Reinstall Shift **** by turning clockwise
Place radio back into position
Tighten screws to hold radio in place
Radio and temp control bezel in place
[IMG]http://i76.photobucket.co
PRO50SC is offline
Old 07-05-2010, 08:12 PM
meganjoe
meganjoe's Avatar
nice write-up!!
I have a question though... how did you get to the front 2 bolts that hold the shifter boot in place??
Thanks, Joe
meganjoe is offline
Old 07-05-2010, 09:13 PM
AdderMk2
Banned
AdderMk2's Avatar
Originally Posted by meganjoe
nice write-up!!
Thanks, Joe
AdderMk2 is offline
Old 07-06-2010, 04:17 AM
meganjoe
meganjoe's Avatar
That looks like the shifter itself.. I meant the 2 front bolts of the piece on top of that...
Thanks, Joe
meganjoe is offline
Old 07-06-2010, 04:18 AM
5.0stang123
5.0stang123's Avatar
Looks like he has a section cut there ^ I had to take center console out.
5.0stang123 is offline
Old 07-06-2010, 08:22 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I use a 5/16 gear wrench
mjr46 is offline
Old 07-06-2010, 10:11 AM
nacanitihs
nacanitihs's Avatar
Thanks, Joe
ya to remove those two you have to remove the center console. looks like someone had already replaced the shifter in that car and reinstalled the stock one when they sold it and didnt replace the front two bolts
if you look at the 12th pic you see him removing the back two but the front two are tucked under the console itself.
also in the pic that adder showed the console is broken at that point for the front two shifter bolts. here you need to use a wrench because a socket wont work with out the broken console. that is if the front two shifter boot bolts are already removed otherwise when the console it out you can use a socket
nacanitihs is offline
Granatelli Sales
01-20-2020 12:34 AM
09-03-2015 07:14 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Short throw shifter install
