How do you remove fuel injectors?
Old 12-03-2007, 07:30 PM
djh1121
djh1121's Avatar
Default How do you remove fuel injectors?
I'm in the process of taking my lower intake off to replace the gaskets. My question is how do take the fuel injectors out? Or is better to unhook the fuel rail or what? Help me out, I'm stuck...
Thanks...
djh1121 is offline
Old 12-03-2007, 07:48 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: How do you remove fuel injectors?
Yup, 2 bolts in each side of the rail. Then lift it off. There may be some resistance but they will come. Make sure you get the o-rings out of the manifold in case they come off the injectors.
You can leave the injectors in to replace the gaskets. Save you some time.
PRO50SC is offline
Old 12-03-2007, 07:58 PM
djh1121
djh1121's Avatar
Thanks for the reply PRO... If I leave the injectors in how do you take the intake off with the fuel rail still attached to the lines? What's the best way for me to tackle this task... Will I swrew anything up by pulling the injectors out?
djh1121 is offline
Old 12-03-2007, 08:02 PM
cleanfitty
cleanfitty's Avatar
You just have to disconnect the lines... sortof near the oil fill cap... you'll need a special tool though.
cleanfitty is offline
Old 12-03-2007, 08:16 PM
djh1121
djh1121's Avatar
ORIGINAL: cleanfitty
So that is better then pulling the injectors? I see that disconnect points just need to get the special tool.
djh1121 is offline
Old 12-03-2007, 08:49 PM
cleanfitty
cleanfitty's Avatar
Yes, just disconnect the two lines using the special tool, and pull the lower intake complete with the injectors and the lines still attached to them. (at least this way there isnn't going to be any chance of damaging the o rings and having any leaks) - this way won't disturb any injectors.
Old 12-03-2007, 08:52 PM
AdderMk2
Banned
AdderMk2's Avatar
if you follow the fuel lines to the passenger side rear corner of the engine bay, you will find where they connect to the metal lines.
two small plastic clips, and the whole line disconnects
AdderMk2 is offline
09-16-2015 07:53 PM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
uedlose
09-10-2015 01:37 PM
Quick Reply: How do you remove fuel injectors?
