How do I wake up my AOD?
Old 12-12-2007, 12:53 PM
djh1121
djh1121's Avatar
Default How do I wake up my AOD?
I'm getting ready to drop in some 4:10's soon and just wanted to see what you guys do to wake up your AOD's some. Or is it even worth the $$$?I plan on doing a T-5 swap one day but for now I'm keeping the AOD. Don't want to put a ton of $$$ in the trans but wanted to see if a shift kit and/or stall converter would help.
I'm just looking for some input or what you have done. Give me some ideas or options...
Thanks
djh1121 is offline
Old 12-12-2007, 01:55 PM
highway21
highway21's Avatar
Default RE: How do I wake up my AOD?
not worth the money 2 put in that trans if ur not going 2 do the works 2 it, like manual valve body and full race rebuild..... just save ur money for that t-5...i went race c4 for around 1000..just a manual valve body for the aods r bank....600-700 bank lol...so dont waste the money unless u realy want 2..but shift kit willl wake her up for around 100-150...but honestly would be alot btr just 2 waite for the t-5...patience man lol
highway21 is offline
Old 12-12-2007, 02:02 PM
94Yellow50
94Yellow50's Avatar
yah..if your not gonna be doin the swap sooner than a year ..id put a shift kit in...not difficult..but the difference just from a stock aod-e to a t5 is great..just got done with mine before winter hit...so idk if your plannin the swap soon..save the moneyn maybe use it for a nice new clutch for your swap and just drive the aod for a while
94Yellow50 is offline
Old 12-12-2007, 04:47 PM
PJB
PJB's Avatar
I put a shift kit and stall converter in mine but I wish I didnt waste the money because now Im swapping the aod for a t5.
PJB is offline
Old 12-12-2007, 05:10 PM
92cobra
92cobra's Avatar
one thing that you MIGHT be able to do cheaper then a t5 swap is to go with a manual valve body from like lentech, and a b&m hammer shifter. This would let you control your shift points from 1st, to 2nd, and YES you can hold 2nd to any rpm, then shift into OD which would be 3rd, and if you need overdrive its on an electric switch/button. Thats just my 2cents tho. I know b&m hammer shifters are really fun in aode cars, but in an aod car its really dumb to have, its more for looks then anything.
But in my opinion, its always better to sell the aod, and buy a t5 then it is to do the swap. Much cheaper, and much easier.
92cobra is offline
Old 12-12-2007, 05:49 PM
FLcracker9
FLcracker9's Avatar
Drive it like it is, and save your money for a C-4
FLcracker9 is offline
Old 12-12-2007, 05:52 PM
92cobra
92cobra's Avatar
i needa post this before dimebag does. BUY NOS!!! lol <3 dimebag.
92cobra is offline
Old 12-12-2007, 06:31 PM
stangman94
stangman94's Avatar
stall, shift kit, adjusted shift pints and it will be more consistent and just as good as a 5spd only downside is the fun factor if you like shifting.
Is the c4 a 4spd with od as as the 4th gear or is there no od?
stangman94 is offline
Old 12-12-2007, 08:16 PM
nitrous_bob
nitrous_bob's Avatar
AT MINIMUM>>>>>>>
4.10 gears and 3000 stall
any less on either and you will be dissapointed
shift kit too, and a cooler, heat kills aod's , stop doing the "shuffle" if you do do it
you will very surprised at the diff of a t5 or c4....i have owned 2 aod cars and 3 t5 cars....my fastest aod got smoked by my slowest t5
and that slow car was 100% bone stock, 2.73 gears and street tires w/ 130k miles on it
nitrous_bob is offline
PJB
PJB's Avatar
A c4 is a 3 speed with no od
PJB is offline
Quick Reply: How do I wake up my AOD?
