battery wont keep charge?
RE: battery wont keep charge?
ORIGINAL: splash21
you could still have a messed up alt and run it. there are 3 coils in the normal alt. it is very common to break just one of them and produce around 1/3 the power. what kind of batt and what alt did you get?
ORIGINAL: kumay91
YOU CAN CHARGE YO BATTERY START THE CAR AND LET IT RUN AND THEN DISCONNECT THE BATTERY CABLE(WHILE CAR IS STILL RUNNING) IF IT TURNS OFF THEN YOU HAVE A BAD ALTERNATOR, OR YOU MAY HAVE A BAD SOLENOID, WAT YOU CAN DO IS HAVE SOMEONE TRY TO START THE CAR AND WHILE IT TRYS TO CRANK HAVE SOMEONE TAP THE SOLENOID, OR JUS CHECK ALL CABLES AND MAKE SURE EVERYTHING IS IN GOOD CONDITION SO YOU DO SPEND MONEY ON AND EXPENSIVE PART THAT YOU DONT NEED
haha i remember using vat 40s.. great machine but no matter how bad it is for the electronics on the car taking the batt cables off of a car while it is running shouldnt make it cut out the alt will make it stay running,usually. but doesnt always mean it is bad if it cuts out. in highschool we had a few "shop" cars that we didnt keep batts in. we just jumped em with a power pack and moved em around that way but it was no biggie if we broke them it just gave us something to do that day.. about the stock 75 amp alt.. i know what you mean but didnt know if he put a different style in. thats why i asked what alt he got.
ORIGINAL: neutralpinned
does anyone else yell in their head when they read text in all caps? I KNOW I DO!
And it could also be fuses or a loose connection, seeing as how you said you got new stuff not too long ago. As my friend said to his ex - go get tested.
ORIGINAL: splash21
i forgot to mention we took the packs off. you dont have to have a battery in to run a car. you do not need a battery for a ground.. the electricity will flow freely throught the body and motor and back around therefore completing the circuit. trust me ive done it a million times and im goin for electrical engineering.
the batt is actually in a seperate circuit. it starts the car initially sending power to the starter and then the alt circuit takes over making spark and recharging what was used from the battery for the start.
as long as engine has a way of initially starting it does NOT need the battery
well........i think the battery was just drained to far, but i am in the middle of putting a shift kit inso if it doesnt work, then ill probabaly have to get a new battery. When i chargedd it last night,the trickle charger took FOREVER before it rejistered 100%
ORIGINAL: mjr46
[sm=wtf.gif][sm=wtf.gif][sm=WTFsgign.gif][sm=yikesomg.gif][sm=noooo.gif]...uhhh no!!!!!! any car will die when you do that because you are removing the ground by which all systems are operating off of......and that's a good way to cause a voltage spike and take out a ecm....never remove the cables while the car is running and when the car shuts off that does not indicate a bad alt!! that is not even a valid test you are speaking of and has no relation to the charging output test and or ability of the alt to charge.....to correctly test an alt you need a multimeter with a voltmeter function and or amps function to test voltage and amperage output......and the way you test for that is place the system under a load by turning on all accesories which will place a load on the alt and field the alt so it starts outputing more amperage to supply the proper amount of current to the demands required....or just simply use a VAT 40/45 to run the test
ORIGINAL: kumay91
