kenne bell
Old 12-15-2007, 12:44 PM
  #21
dillon1340
dillon1340's Avatar
Default RE: kenne bell
ORIGINAL: r.barn
You will need
new fuel pump .... $100
new MAF and injectors ..... $400-500
Computer tune ...... $500-750
King Cobra Clutch ..... $175.
Will be pushing stock trans, but should hold up ok.
Suggestion?
You can get a turbo kit $2,900 or $600 less than the
KB and make more power and have same off the line torque.
HIGHLY recommend a turbo over the KB
www.quicktimeturbosystems.com
holy cow that is probably the cleanest fox body turbo setups i have seen. and the price is reasonable too.
dillon1340 is offline
Old 12-15-2007, 01:15 PM
  #22
w8less
w8less's Avatar
guys, guicktime is local for me. i can give actual dyno results of cars they he has installed the kits on.
w8less is offline
Old 12-15-2007, 02:27 PM
  #23
OnyxCobra
OnyxCobra's Avatar
I am most likely still going with a KB b/c I've always wanted one and love the simplicity of the setup. Doesn't make bad power at all either and I love instant torque. Turbo cars drive me crazy sometimes in terms of how they drive.
OnyxCobra is offline
Old 12-15-2007, 04:06 PM
  #24
Mustangkiler
Mustangkiler's Avatar
Just something about the kb maybe its from watching mad max too many times.
Mustangkiler is offline
Old 12-15-2007, 04:07 PM
  #25
94Yellow50
94Yellow50's Avatar
ya..gotta agree..nothin like driving along..coming up next to someone with a kb...n listenin to them get all over it....music to my ears...
94Yellow50 is offline
Old 12-15-2007, 04:41 PM
  #26
DickH
DickH's Avatar
Does the kb for the 5.0 make the whine like on the 03/04cobra?
DickH is offline
Old 12-15-2007, 06:07 PM
  #27
Rixter
Rixter's Avatar
I think unless you're actively competing with it, you might as well go with what you want rather than what necessarily makes the absolutely most possible power ever possible with your car, unless of course all you want is the absolutely most possible power ever possible with your car. The whine of a supercharger is worth something in and of itself.
Rixter is offline
Old 12-15-2007, 06:22 PM
  #28
Mustangkiler
you can barely hear mine whine, all you hear is the engine screaming when u get on it but of course im not running 20 lbs like they do on cobras.
Old 12-15-2007, 10:24 PM
  #29
OnyxCobra
OnyxCobra's Avatar
KBs whine on 5.0s but it's not nearly as loud as on the Termys and I think it's b/c most of them are running under 10psi, like Mustangkiler mentioned.
Old 12-15-2007, 10:27 PM
  #30
r.barn
r.barn's Avatar
Yeah its the higher boost pulleys that make em scream
cause their rpms are so much higher with the smaller pulley
17-20psi pullied 5.0 KB would make a ton of noise too, I bet.
r.barn is offline
Quick Reply: kenne bell
