Rear coils.
Old 12-15-2007, 04:05 PM
Jfsram
Jfsram's Avatar
Default Rear coils.
After removing the rear shock absorbers. Will the rear axle hang down low enough to remove the coil spring?
Or will I have to disconnect the control arm/arms?
Jfsram is offline
Old 12-15-2007, 04:06 PM
primetime5.0
primetime5.0's Avatar
Default RE: Rear coils.
have someone stand on it, and push it down, it should come out after that
primetime5.0 is offline
Old 12-15-2007, 04:40 PM
HACKGT350
HACKGT350's Avatar
disconect the quad shocks too. if thats not enough just undo the control arms at the axel and the springs will come right out
HACKGT350 is offline
Old 12-15-2007, 06:09 PM
Mustangkiler
Mustangkiler's Avatar
Took off the shocks and quad shocks andi could pull mine right out.
Mustangkiler is offline
Old 12-18-2007, 06:00 PM
Jfsram
Jfsram's Avatar
Got them out. Thanks for the replies.
Used a bar to pry the axle down at bit and a few hose clamps to compress the spring a bit. Not like a spring compressor and compress the entire spring. Just to shorten a few rings about 1/4". It was enough to get them out.
I added some spacers under the bottom isolator. The were about 3/8" thick and now the car sits about 3/4" higher.
I'm lowered with Eibach springs, I think the Proline kit.
Too low for daily used, especially winter.
This gave me a tad more ground clearance. I may take them back out when I switch back to my summer tires.
Jfsram is offline
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
UrS4
09-30-2015 10:13 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Rear coils.
