not firing up fast enough!!
Old 12-15-2007, 08:59 PM
1mean5.0
1mean5.0's Avatar
Default not firing up fast enough!!
When I start my car It turns over for about 5-8 seconds before is fires up. Is this not typical for an 89? And if not what can I do to fix the problem?
1mean5.0 is offline
Old 12-15-2007, 09:54 PM
maiello2169
maiello2169's Avatar
Default RE: not firing up fast enough!!
pull the plugs and see what they look like. when is the last time your fuel filter was changed?
maiello2169 is offline
Old 12-15-2007, 10:27 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Is this everytime or the first cold start of the day?
PRO50SC is offline
Old 12-15-2007, 10:51 PM
1mean5.0
1mean5.0's Avatar
yeah mostly the first cold start of the day
1mean5.0 is offline
Old 12-15-2007, 11:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to check all ignition componentslike worn plugs.....but I might lead towards carbon build up in the intake and cumbustion chambers...also check fuel pressure with a gauge and make sure no leak down is occurring
mjr46 is offline
Old 12-16-2007, 07:23 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: 1mean5.0
Cycle the key on/off 2 or 3 times and see if it fires right up. If so, most likely the f/p is leaking down or an injector.
PRO50SC is offline
Old 12-16-2007, 10:32 AM
LTnone
LTnone's Avatar
ORIGINAL: PRO50SC
Like my ZX2's is doing right now
At least the Mustang's fuel pump job didn't involve rust [>:]
LTnone is offline
Bokeo
10-10-2015 08:28 PM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: not firing up fast enough!!
