Suspension lean
Old 12-18-2007, 03:22 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: Suspension lean
Struts and shocks don't effect how your car sits so I'd rule that out. If you havn't checked out the springs closely lately check them again, it's possible they broke.
OnyxCobra is offline
Old 12-18-2007, 04:12 PM
ltrayne84
ltrayne84's Avatar
I've checked them out myself and i've had a buddy of mine check them out. We even swapped the passenger rear ones to the driver's side. But i'm definately going to check the control arms.
ltrayne84 is offline
Old 12-18-2007, 05:52 PM
Jfsram
Jfsram's Avatar
One thing you can try.
Clock the rear springs to a different position.
You know how the top of the rear coil springs are flat at the top. Obviously, no difference in height, no matter where they are rotated.
The bottom may give you a bit more or a bit less if that last tail of coil spring is at the front of the coil spring pad or at the rear of the pad.
That pig tail end is on a slight angle, making it effectively useless for first half a ring, depending on how it sits on the flat pad.
Not sure if this can give you that 1/2" you are looking for.
It's just a theory. If you can find an 1/8" of an inch with this. Which is almost a 1/4" at the wheel/axle. Add one side, take away from the other. Ok, I'll shut up now.
Jfsram is offline
Old 12-19-2007, 08:58 AM
ltrayne84
ltrayne84's Avatar
thats some good advice... but i want to make it sit right and not just rig it up so that it looks right...thanks though
Old 12-19-2007, 11:58 AM
PearlWhiteGT
PearlWhiteGT's Avatar
I'm kind of having the same problem as you are. The rear of my fox sits uneven.The drivers side sits a little lower that the passenger side. I plan on getting some new springs, shocks, struts, isolators, etc....
PearlWhiteGT is offline
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension lean
