Reving higher than stock tach???
Old 12-20-2007, 07:59 PM
telsonman
telsonman's Avatar
Default Reving higher than stock tach???
How do you know when your tach has increased over the 7000(i think) on the stock tach??? I've been told that when you put bigger rockers on that it raises the level of RPMs the car can handle. Like my shift light i think goes up to 13k. What kind of mods does a 5.0 need to where you can shift at say 6500 and not have to worry about blowing a head gasket or really F*** things up???
telsonman is offline
Old 12-20-2007, 08:06 PM
92cobra
92cobra's Avatar
Default RE: Reving higher than stock tach???
6500 is pretty high, your not there yet i can tell ya that. I bet if you had your car on a dyno you would start to fall out around 5800rpms give or take. Thats about where i would be shifting if i had your car.
92cobra is offline
Old 12-20-2007, 08:13 PM
Bobert
Bobert's Avatar
Yea man thats nuts, i would never rev mine that high. If you plan on going over 6500, i would worry about the head gasket, id be worried about the hole in my oil pan made by the rod
And the needel at the very bottom would be a good sign? IF it passes the stock marker, your going to hear nosie.
Bobert is offline
primetime5.0
primetime5.0's Avatar
my car goes dead over 5000, new motor will spin to fuel cutoff no problem 6250
primetime5.0 is offline
Old 12-20-2007, 08:24 PM
86 5.0L
86 5.0L's Avatar
your internals dictate how high you can rev
86 5.0L is offline
Old 12-20-2007, 09:19 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: 86 5.0L
valve springs too, also how well the motor is balanced, etc. I think there are several factors.
OnyxCobra is offline
Old 12-20-2007, 09:45 PM
greenstreak9205
greenstreak9205's Avatar
yea i would bet that it drops off before 5800 w/out a doubt. and valve springs are internal...well at least to the valve covers
greenstreak9205 is offline
FivePointToTheOh
03-09-2020 10:26 PM
guitarman376
10-11-2015 01:47 AM
ccdguy
09-19-2015 05:20 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Reving higher than stock tach???
