squiters spraying bythem self!
I have a 650 dp with a profourm main body , every time i would dive it and stop to go in some were and come back out it would be flooded , to the point that the LM1 just says TOO RICH , so to day i went up town and came back out to leave it was flooed , i poped the hood and took off the air cleaner and to my suprize ever few sec. the squites would dispurting fule on there own , what could cause this???[/align]
RE: squiters spraying bythem self!
wow that is weird. is the fuel pressure building up somehow and releasing the pressure that way? i really don't remember much about carbs anymore, hope someone can help you with that
Your floats are stuck!! When they are stuck, the needle stays open andkeeps forcing fuel out your squirters instead of stopping the flow. Just tap your back bowl or take the 4 5/16 bolts out and spray some carb cleaner in it!
You say squirters? Do you mean the squirters that spray when you pump the gas or the venturies?
Is this happening with the pump off?
Are youusing a regulator? Did you check your fuel pressure?
7 psi. max or you will bypass the needle and seats.
Adjust the float level.
You should check your fuel pressure. You might be running it to high, and when the system keeps too much pressure in the lines it could force it out of the carb. Interesting dilema...
dochawk
08-25-2015 08:25 AM
