running rich
running rich
i put 24lb injectors and it seems to run real rich, it has an E 303 cam gt-40 heads cobra intake headers and so on...... i belive with all those modds a chip is needed mine does not have one. If i were to get one burned i was thinking from SCT would that correct the problem and i also just bought a MAF for 24 injectors. What do you guys think?
thanks
thanks
RE: running rich
ORIGINAL: 88 GT CONV
With the exception of engine start up and WOT, the computer monitors the sensors and keeps the injectors in open loop to achieve stoichiometric A/F ratio
RE: running rich
Yeah MJR, I got ya. I think I got my open/closed backwards...You sure open = predetermined parameters? I thought that was closed loop. And i just said that the computer "monitors" the sensors toprevent a long explanation of drivability lol
RE: running rich
ORIGINAL: 93bluestang
the smell is pretty foul no i dont recall seeing any black smoke but i got like 5 psi of vac. i use to have between 17 and 20, before i changed the injectors
