rear end calculation
hi i havent been able to get good info from the calculators above but i have an 89 aod gt when in drive(w/od) at 2000 rpm the car is cruising at 80mph i have 255/40/17 on the back wheels anyone with info on what rear end i have would help. thanks in advance
RE: rear end calculation
sounds like you might have 3.08 or 2.73 ratios take a look at the tag on the pumpkin its held on by one of the bolts for the dif cover and post up what it says it will have the gear ratio on it
easiet way to tell what gear is to jack up car, put in neutral and crawl under and put mark on the driveshaft, then a mark on the tire and count how many times the driveshaft goes around to one revolution of the tire. (ex. 2 3/4 turns of drive shaft = 2.73 gears.....)
easiest way to tell is sitting at your computer lol. http://www.angelfire.com/fl/procrastination/rear.html
25" tire size using a different calculator
.67 transmission final gear ratio
2000 rpm
80 mph
2.73 final drive ratio
2000 rpm
80 mph
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
