Black magic Electric fan need some help
Old 12-27-2007, 08:12 PM
steve355
steve355's Avatar
Default Black magic Electric fan need some help
Can anyone who installed one of these let me know what they used as a keyed on hot source ?
I am a little lazy and hooked it up to a constant power.
steve355 is offline
Old 12-27-2007, 08:51 PM
85stang project
85stang project's Avatar
Default RE: Black magic Electric fan need some help
did you use a relay? if not none
85stang project is offline
Old 12-27-2007, 09:14 PM
steve355
steve355's Avatar
I'm not sure I understand what you mean ?
steve355 is offline
Old 12-27-2007, 09:29 PM
93 LX FiveO
93 LX FiveO's Avatar
that fan is designed to work with the car off.
93 LX FiveO is offline
Old 12-27-2007, 11:19 PM
piedraco
piedraco's Avatar
i hooked mine up to a switch inside the car. There should be a harness that runs next to the battery that you can tap into in order to get a signal to the box for it to turn on and off. Also you need to use the A/C compressor harness and tap that to get the fan to turn on when you crank the A/C unless you dont have A/C.
piedraco is offline
Old 12-28-2007, 12:09 AM
yellow93lx
yellow93lx's Avatar
It has been a while, but I think this is the wire mine is hooked to and it is hot only when the key is on.
[IMG]local://upfiles/57954/1C540CCB47514305BC4E4485015E01D4.jpg[/IMG]
yellow93lx is offline
Old 12-28-2007, 07:19 PM
steve355
steve355's Avatar
thanks for the help.
steve355 is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Dathan
10-05-2015 05:52 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
Quick Reply: Black magic Electric fan need some help
