car won't start please help
Old 12-28-2007, 11:05 PM
irishdo30
irishdo30's Avatar
Default car won't start please help
Ok just tried taking my car out of the garage for a mid winter drive, car wouldn't start. It's an 1989 GT engines stock w/ CAI i turn the key to start it and all i hear is a continous clicking from the solenoid. I tested the ignition coil, replaced the starter and solenoid is good, car still won't start. The only other piece i didnt check is the ignition switch. I'm not sure if the ignition switch would stop the car from starting with a push start so if anyone knows the answer to that question that would help. I checked all the connections and wires and they looked good as far as i could see. Anyone have an ideas? Thanks in advance
irishdo30 is offline
Old 12-28-2007, 11:17 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
Default RE: car won't start please help
the starter? correct me if im wrong.
rust_stang is offline
Old 12-28-2007, 11:19 PM
irishdo30
irishdo30's Avatar
just put a brand new one in
Old 12-28-2007, 11:21 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
oh lol. []
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
is the battery good and if so how do you know?? turn the lights on are they bright as can be????
mjr46 is offline
Old 12-28-2007, 11:31 PM
irishdo30
irishdo30's Avatar
battery is good and also did it while being jumped. When i tried to push and pop the clutch 2 start it, it sounded like it started as far as the exhaust goes then just died, would a bad igntition switch cause this?
Old 12-28-2007, 11:49 PM
mjr46
mjr46's Avatar
so you have a no crank condition?? if so you can test the lead to the selonoid that is powered by the ignition.....it is the small wire with the little elbow on it that attaches to the selonoid...with the key in the crank position it should light a test light = hot in crank and not hot in the koeo mode
mjr46 is offline
Old 12-28-2007, 11:55 PM
irishdo30
irishdo30's Avatar
if i take that elbow off and short the solenoid does that mean it should start because i tried that and it doesnt
Old 12-29-2007, 12:01 AM
irishdo30
irishdo30's Avatar
im pretty sure that elbow is gettin power because with it off tryin 2 start the car nothing happens, with it on the solenoid clicks repeatedly
Old 12-29-2007, 12:06 AM
mjr46
mjr46's Avatar
take the cable that goes down to the starter and touch it / jump it to the allways hot / batt side of the selonoid
mjr46 is offline
Quick Reply: car won't start please help
