Trick Flow Pushrod length
I wanted to double-check my pushrod length. I'm installing a set of TFS small-block heads, and I'm using a set of proform roller-rockers. I ran my pushrod length checker and came up with a number of about 6.45 inches. Trick Flows website says that the pushrods are longer than normal, and 6.45 is definately longer than the stock rods I pulled out some time ago (I still have them to compare. 6.45 comes out to 6 and 7/16ths and a hair.
No modifications to the block or heads.
RE: Trick Flow Pushrod length
so what's the question you want an answer to?? will it work??? if that's the question then it should all work..the trick flow kit I did on a 94 cam out good with the supplied push rods in the kit..but when you get them..mock assemble it and double check..better to be safe than sorry
junior04
09-28-2015 10:53 AM
Daddys Girls GTs
09-14-2015 08:46 PM
