91 LX Will not start
Hey guys. I need help from you stang experts out there. My 91 LX just refuses to start.
Here is what I have done to troubleshoot the problem in steps of course:
-Verified spark....all cylinders good
-Verified fuel...all plugs new and wet
-Replaced TFI module in distributor
-Verified all engine compartment connections are connected
-Verified mass air sensor good with another new one I have
-Verified TPS sensor idle and WOT voltage
-Replaced battery with brand new Optima
-Replaced Cap, Rotor, and Coil
I was going to spray this car for a while while my stroker motor is being built.
The car cranks but wont light off. The only thing left to replace would be the plug wires and the IAC sensor. Any help would be greatly appreciated. Thanks.
RE: 91 LX Will not start
Plug wires have nothin to do with the problem.
Are you positive that you have spark in every plug? If you have spark and fuel in each cylinder. Id be willing to bet that your dizzy is backwards. Making your motor completely out of time. But if you didnt touch your dizzy since you have last fired up the car, then thats ruled out.
If its not the dizzy, maybe your lacking compression(do a compression test?) or maybe you are extremely lean or rich. Is it possible to bypass the IAC by opening the throttle?
Yeah. I knew the wires were not the issue. Dizzy has not been removed since it last run. I failed to mention this. About a week ago the car backfired out the upper intake. I think it did because I had the TPS sensor voltage way too high. So maybe the timing chain jumped. Next thing will be to verifly TDC on #1. If its off then it looks like Im replacing the timing chain.
Update. Verified TDC #1 and the timing. Its correct. But still refuses to start. Could it be my IAC valve? I figured if that was bad it would just idle like crap. The car still refuses to start. I bought a Prof Products Throttle body and EGR spacer off of ebay. Has anyone had problems with these things. I know they are cheap and you get what you pay for. Just wanted to know..thanks.
so you are basing you got fuel by saying the plugs are wet??.....#1 when you turn the key on can you hear the pump in the tank run for a few sec??? then go off??....did you check for fuel pressure with the proper tester?? = hooked to the fuel rail......also you have verified spark via a inline spark checker right??? when you spray ether in the intake will it fire up briefly??? also do you have injector pulse..and a IAC motor has nothing to do with your problem save your money for now
ORIGINAL: mjr46
so you are basing you got fuel by saying the plugs are wet??.YES....#1 when you turn the key on can you hear the pump in the tank run for a few sec??? YES then go off??..YES..did you check for fuel pressure with the proper tester?? YES= hooked to the fuel rail...YES...also you have verified spark via a inline spark checker right??? YES when you spray ether in the intake will it fire up briefly???NOT TRIED YET also do you have injector pulse YES..and a IAC motor has nothing to do with your problem save your money for now I AGREE
dalefrancis88
09-11-2015 07:15 AM
