Clutch Pedal
Old 01-06-2008, 01:47 PM
65coupe88hatch
65coupe88hatch's Avatar
Default Clutch Pedal
So i dont know if anyone remembers my thread awhile back about the small whineing noise from the tranny. but that went away but i also mentioned a vibration from the pedal....welp i now know that the pedal isnt sitting where its supposed to. The pedal is up too high and when i "rest my foot on it" it sets it back to where its supposed to be mountd at. now my question is how do you adjust the pedal??? i have a new clutch cable in it if that makes ne difference.
65coupe88hatch is offline
Old 01-06-2008, 02:28 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Default RE: Clutch Pedal
Have you tried lifting up on the clutch pedal to reset the quadrant?
ALMOST STOCK is offline
Old 01-06-2008, 02:45 PM
65coupe88hatch
yeah, it didnt do anything. vibration is still there.
Old 01-06-2008, 04:16 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you just changed the cable you'll have to reach under the dash and try to manually reset the quadrant..I had to do this once or twice on mine when it over racheted with no cable hooked up...it's worth a try
mjr46 is offline
Old 01-06-2008, 04:33 PM
65coupe88hatch
how do you go about manually resetting the quadrant...?
Old 01-06-2008, 05:37 PM
mjr46
mjr46's Avatar
There is a little rachet tab under there and it's held against the teeth vis a spring pressure......push it open and pull up on the pedal..Iusually have to stick my head up under there to see it
mjr46 is offline
Old 01-06-2008, 05:44 PM
stang8689
stang8689's Avatar
I would get a firewall adjuster and quadrent, they are fairly cheap
stang8689 is offline
Old 01-06-2008, 07:23 PM
Streetracer911
Streetracer911's Avatar
http://www.corral.net/tech/drivetrain/clutcha.htm
Try that link
Streetracer911 is offline
Old 01-06-2008, 07:45 PM
65coupe88hatch
thanks for that link, ill try that tomorrow. hopefully it fixes it.
Old 01-06-2008, 07:46 PM
Streetracer911
ORIGINAL: 65coupe88hatch
I have yet to try that, but I do plan to do that in the spring time when the stang is out of hibernation.
Quick Reply: Clutch Pedal
