gt wont start
Old 01-07-2008, 04:39 PM
simpsonfan13
ELEKTRO-FIDE Moderator
simpsonfan13's Avatar
Location: In Geo-synchronous orbit over redass' bathroom,
Default gt wont start
so my 89 is dead again.
i just replaced the battery and alternator (stock one[>:])
what could be wrong????
i hear a grinding noise so im thinking starter
opinions?
simpsonfan13 is offline
Old 01-07-2008, 04:51 PM
kuskye25
kuskye25's Avatar
Default RE: gt wont start
i would tend to think starter, at most take it out and see whats up.
test it/ look at its teeth and spring engaugement...
kuskye25 is offline
Old 01-07-2008, 04:52 PM
DrmZero
DrmZero's Avatar
yea if you are hearing a girnding then its your starter.. you could try hitting it with a hammer a couple times to knock it loose... if it doesnt work just get a new one.
DrmZero is offline
Old 01-07-2008, 04:55 PM
fourfivefour
fourfivefour's Avatar
The battery dead and a bad starter are two different problems.
Which is it?
Dead battery?
Bad starter?
If your battery is going dead when the car sits a new starter will not help that.
With everything turned off and the doors closed and the hood light unplugged.
This is called checking for a draw:
Disconnect the negative battery cable and hook a test light between the negative cable end and the batteries negative post. The light should not light up brightly. A little dim is ok but a bright light would indicate a current draw. You need to find what is on or shorted.
If the starter is worn out and drawing a lot of ampsmaking itseem like the battery is dead?
WHICH IS IT?
fourfivefour is offline
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: simpsonfan13
opinions?
So did you replace the battery and alt because they were bad or because you thought that may fix your problem?
A dragging starter will draw up to three times the current it normally needs to turn over. Take it out, clean it, have it bench tested.
Derf00 is offline
Old 01-07-2008, 06:29 PM
simpsonfan13
i replaced the battery and alternator cuz the battery kept dying.
i replaced the one (battery) it was sold to me with and it died like in two days.
i replaced it again and bought a new alternator. the battery has lasted
for a good while now (~a week). i know think it`s the starter
because of the noise i keep hearing, and the fact that my dad couldnt start it a day agao and i started it yesterday on 3
non-consecutive ocations.
and fourfivefour
what do you mean by hood light? how do you uninstall it?
also are test lights available at say napa?
Old 01-07-2008, 06:52 PM
simpsonfan13
bumpage?
Old 01-07-2008, 07:20 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
and fourfivefour
THE PROPER WAY TO check for a parasitic draw is to use a multimeter set to the amps function.....and why not a test light???? because when you have a draw of lets say slightly over a 100 milliamps vs the safe max spec of 25-50 milliamp..then it'll be very difficult to determine if you've eliminated all of the draw....a test light will work for a large draw but not very accurate for small ones......so pull out your ammeter and remove the neg battery terminal and hook the multimeter/ammeter in series and if there is no draw on the battery at rest you should get a reading of 25-50 milliamps max.....make sure all doors are shut..glove box light and trunk light off and sunvisor lights off and under the hood light unplugged when checking for a parasitic draw
mjr46 is offline
Old 01-07-2008, 07:36 PM
ewgoetz
ewgoetz's Avatar
It was fine for 2 days than went bad?.....Does it have under drive pulley's?
ewgoetz is offline
Old 01-07-2008, 07:41 PM
fourfivefour
ORIGINAL: mjr46
because of the noise i keep hearing, and the fact that my dad couldn't start it a day ago and i started it yesterday on 3
non-consecutive occasions.
and fourfivefour
THE PROPER WAY TO check for a parasitic draw is to use a multimeter set to the amps function.....and why not a test light???? because when you have a draw of lets say slightly over a 100 milliamps vs the safe max spec of 25-50 milliamp..then it'll be very difficult to determine if you've eliminated all of the draw....a test light will work for a large draw but not very accurate for small ones......so pull out your ammeter and remove the neg battery terminal and hook the multimeter/ammeter in series and if there is no draw on the battery at rest you should get a reading of 25-50 milliamps max.....make sure all doors are shut..glove box light and trunk light off and sun visor lights off and under the hood light unplugged when checking for a parasitic draw
Very small/milliamp draw will not kill the battery over afew daysof sitting.
If you only have a test light it will work fine.
Quick Reply: gt wont start
