What fuel pump to purchase?
Old 01-07-2008, 08:23 PM
dantheman345
dantheman345's Avatar
Default What fuel pump to purchase?
Check my signature for engine specs. I have not looked at my current fuel pump but I know it going bad so what type should I get and how many lph or gph should I get?
dantheman345 is offline
Old 01-07-2008, 08:59 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: What fuel pump to purchase?
ORIGINAL: dantheman345
I assume your car in the sig is the one you are making reference too right?? and it's carbed right?? if so..are you still using a mechanical pump bolted to the timing cover?? if so you can get a holley one that puts out max 6 to 7 psi and if you really want something that is not rpm dependent..then go electric..I got the holley blue with and external regulator...and it puts out 14-15 psi AND I have it adjusted to 5.5 psi and I run NOS.....pump is a little noisy but works great
mjr46 is offline
Old 01-07-2008, 09:03 PM
lxman1
lxman1's Avatar
Mallory Comp 140 pump with regulator is a great pump if you want to go electric. It is a gerotor design like an oil pump. Very smooth and reliable. Quieter too.
If you're gonna stay mechanical. a Edelbrock or Holley pump will work good too.
lxman1 is offline
Old 01-07-2008, 09:37 PM
dantheman345
I assume your car in the sig is the one you are making reference too right?? YES
and it's carbed right? YES its a 650 Thunder carb
I found out that I have a electric pump on right now. It was purchased in 1999 from summit for $75.00 and they no longer carry it.
Old 01-07-2008, 09:43 PM
mjr46
mjr46's Avatar
just replace it with one of similar nature holley sells a red that is regulated to 7 psi max or the blue with an external regulator...either would be a good choice or look aroung for other ones of similar nature
mjr46 is offline
Old 01-07-2008, 10:08 PM
dantheman345
I just bought the holley blue with Reg off ebay for 115 shipped. Anything I should know when installing it?
Old 01-07-2008, 10:15 PM
mjr46
mjr46's Avatar
no just make sure you adjust the regulator down to 5-6 psi max.....you'll need a gauge installed on the regulator..that's what I did..and you may have to purchase a few ****** ends to screw into the inlet and outlet port on the pump..as I don't think the pump comes with all that...but I may be wrong..I bought mine over 4 years ago so I don't remember...and don't be suprised..the holley blue is a little noisy..but then again so was my car!!! lol
mjr46 is offline
10-26-2015 05:01 PM
Meystang
09-25-2015 04:05 PM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: What fuel pump to purchase?
