ENGINE SWAP
Old 01-08-2008, 05:43 PM
matt_5.0
matt_5.0's Avatar
Default ENGINE SWAP
hey guys thatnks for reading... i have a 92 ford f 150, with the 5.0... i was wondering what i have to change to put it in the stang?
matt_5.0 is offline
Old 01-08-2008, 05:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: ENGINE SWAP
you can use the long block but will have to swap oil pans and or possibly the timing cover
mjr46 is offline
Old 01-08-2008, 05:47 PM
matt_5.0
matt_5.0's Avatar
is that all like for shure? and will it run the same as the regular 5.0 in the original stang?
matt_5.0 is offline
dc_mann8
dc_mann8's Avatar
absolutely dont do it.. they make so little power.
a mustang 5.0 is much much better.
you would need a new intake manifold, the truck one is really high. and youd need a dual sump oil pan to clear the crossmember, much more..
dc_mann8 is offline
Old 01-08-2008, 05:52 PM
matt_5.0
matt_5.0's Avatar
how much would aregular mustang engine out of a 5.0 run me used do you think
matt_5.0 is offline
Old 01-08-2008, 05:57 PM
dc_mann8
dc_mann8's Avatar
2-500
dc_mann8 is offline
Old 01-08-2008, 06:15 PM
mjr46
mjr46's Avatar
ORIGINAL: matt_5.0
cams are different and you'd need to verify it is a roller cam block and that the firing order is the h.o/351 firing order cause if you have a cam in the truck block that doesn't correspond to the h.o firing order it won't work with the sefi on the mustangbesides the truck engine makes less hp stock for stock ..why go backwards on performance
mjr46 is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
97SN95GT
09-13-2015 09:45 PM
mdj89
09-06-2015 11:08 PM
zachary1988
09-04-2015 03:04 PM
Quick Reply: ENGINE SWAP
