do sealants really work??
Old 01-08-2008, 07:57 PM
TripleJay22
TripleJay22's Avatar
Default do sealants really work??
i believe i may be having a head gasket leak and was looking around and seen those engine sealants that supposidly seal head gasket leaks and other leaks permanently... does anybody know if they are worth trying or if they work at all? thanks for the help
TripleJay22 is offline
Old 01-08-2008, 08:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: do sealants really work??
you mean like "bars leak"??? my dad is old school and he swears by the stuff but me if there is a leak I like to fix it right and fix it once......but whatever floats your boat use it...bars leak is good..but some of those sealers can be like glue and end up doing more harm than good by clogging the system up if used in excess...what's the worst that'll happen if it doesn't work?? you'll have to pull the heads which you may already be in line to do[:@]
mjr46 is offline
Old 01-08-2008, 09:29 PM
my77stang
my77stang's Avatar
i hear moroso's ceramic block sealer is supposed to be one of the best ones. of course this is only to be used when your trying to sell a car
my77stang is offline
Old 01-08-2008, 11:22 PM
TripleJay22
im trying to find something as a temp fix until summer when i will have my street bike to be able to drive and actually fix the car properly
Old 01-08-2008, 11:30 PM
87gt5o
87gt5o's Avatar
K&W head gasket and block repair worked on my old 84 Camaro. It takes a full 24 hours to set up, which if you can afford the time, it's good. Worked wonders for me, you can buy it at Schuck's and probably other places. http://www.midwayautosupply.com/pm-1...oz-401232.aspx
I don't know about the silvercan K&W but the green bottle worked for me. I guess it depends on the severity of your blown head gasket too, whether or not sealants will work.
Aside from head gaskets - Bars Leaks rear main seal worked on my 87 GT....great stuff.
87gt5o is offline
HACKGT350
HACKGT350's Avatar
if you want to try a sealer go for it. i dont trust the stuff it clogged my water pump when i used it to seal up my heater core. ended up replacing the heater core and the water pump so its really up to you
HACKGT350 is offline
Old 01-08-2008, 11:39 PM
TripleJay22
its not a huge leak in the head gasket as far as i know i get moisture in one exhaust pipe, and smoke coming out the same one, and slowly lose coolant. so im think i might try it this weekend just hoping for the best.
Old 01-09-2008, 12:18 AM
KOMan
KOMan's Avatar
i'm not sure about head gaskets but it sealed my WP pretty well. i broke 1 bolt by the water passage on each side of the water pump and bars leak is hold just fine. i'll probably fix it when i install the 331 into the car.
KOMan is offline
Old 01-09-2008, 07:42 AM
onesickstang01
onesickstang01's Avatar
i havent used any sealants to repair a leak, i have always fixed the problem correctly but a buddy of mine tried using that crap in his s10 and screwed it up bad. just amke sure you use the exact amount they tell you to
onesickstang01 is offline
Old 01-09-2008, 07:49 PM
TripleJay22
yeah i plan on fixing it correctly but but need a quick fix for now until i have all the time to tear down the engine and what not because im going to be getting heads i beleive when i take the engine apart so its not going to be torn down until summer and cant afford to buy coolant every week until then
Quick Reply: do sealants really work??
