rolling fenders
Old 01-08-2008, 09:48 PM
dillon1340
dillon1340's Avatar
Default rolling fenders
i have searched the forums about rolling fenders but still have a question. i'm going to use ford b springs and i have 245/45 on front with 17x9 275/40 on back. been told i may have to roll fender to not rub. thing that i dont understand is on the front if you roll the fender, the little lip inside, what do you do about the plastic inner fenderwell? what would that attach to? thanks!
dillon1340 is offline
Old 01-09-2008, 06:21 AM
stang8689
stang8689's Avatar
Default RE: rolling fenders
If I can remember right the Ford springs only lower about an inch, if thats the case you should be fine
stang8689 is offline
Old 01-09-2008, 07:25 AM
onesickstang01
onesickstang01's Avatar
you shouldnt have to roll the front. the rear is yor main worry because the fox body sag in the rear. if you are lowering the rear then you will need to watch what tires size you use in there. i have 26/11/15 so my tires fills the wheel well completely and the quarter panel lip is rolled
onesickstang01 is offline
Old 01-09-2008, 10:53 AM
jmyler
jmyler's Avatar
Yea the front is never really an issue, it's the back that people are talking about when they say "rolling the lip". I don't even think you will have much of an issue with those springs, maybe when you hit big dips in the road or have a big dude in the car with you.
jmyler is offline
Old 01-09-2008, 02:59 PM
ALMOST STOCK
ALMOST STOCK's Avatar
The only thing that might rub up front with 245x45 w/ 17X9 would be the inner wheel on the A-arm, which is an fix with rack limiters/ travel restrictors. Other than that you probably won't have a rubbing issue in the front.
ALMOST STOCK is offline
Old 01-09-2008, 09:23 PM
dillon1340
dillon1340's Avatar
yeah i bought rack limiters when i put the wheels and tires on. i didnt have to use them it only rubs on full lock and thats ok. i guess i'll put the springs on and if it rubs THEN i'll worry about rolling the fenders. thanks y'all!
flash_xx
10-16-2015 07:23 AM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
ThatJuanStang
09-25-2015 08:01 AM
zachary1988
09-18-2015 11:17 PM
Quick Reply: rolling fenders
