O/R Pipes and Emissions
Old 01-09-2008, 02:59 PM
camaroeater
camaroeater's Avatar
Default O/R Pipes and Emissions
Dumb ?... but can't find the answer...can i do a O/R H or X PIPE in Arizona?? Seems more than half the people on here got the O/R.
camaroeater is offline
Old 01-09-2008, 03:05 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: O/R Pipes and Emissions
ORIGINAL: camaroeater
They will run your car on a Dyno if your car was built before 95 (Pre OBDII). I doubt you will pass the NoX readings without the cats on.
Answer: Yes you can but you will probably need to put the catted crossover back on for emissions purposes.
Derf00 is offline
Old 01-09-2008, 03:22 PM
camaroeater
You mean put the O/R on then swap back on stock w/ cats for emissions...I heard of a guy hollowing out the cats so if emmisions checked for them it appeared he had cats.
Old 01-09-2008, 03:43 PM
Derf00
Gentleman's Relish
Derf00's Avatar
That would be if they only did a visual check. Here in AZ they put your car on an emissions dyno. The hollowed out cats would get 'sniffed' out...literally.
Yes, O/R on, then swap it out for the stock w/cats for emissions.
Derf00 is offline
Old 01-09-2008, 03:55 PM
camaroeater
Appreciate it man...the guy i know that hollowed his cats for the visual inspection said it actually passed emmisions better that w cats..ur right though, they'd smell it.
How difficult is it to install/remove an H pipe.
mrtrodonet
09-19-2020 03:12 PM
mrappe
09-26-2015 10:16 AM
09-24-2015 09:18 PM
mltdwn12
09-23-2015 08:54 AM
trashxtrash
09-20-2015 10:49 PM
Quick Reply: O/R Pipes and Emissions
