Breathers
Breathers
Any ideas on what breathers could be oput there that will fit between my valve covers and upper intake? I've heard there are some that have an elbow and help out with clearnance issues, but wondered if anyone knew what they are and where you can find them. I have no problem with my passenger side, but the drivers side is a different story. I noticed after I beat on the car a little, I'll get some oil seapage out of the plug I but in the drivers side valve cover opening and I'm told I need a breather.
Thanks
Thanks
RE: Breathers
ORIGINAL: crocop
alot of people told me that breathers are good for nothing. and there illegal in canada.
RE: Breathers
I was just told by the engine builder that they would help with the pressure build up in the crankcase. I know it's not leaking on the side with the breather in it, if that's any indication.
Why are they illegal in Canada?
RE: Breathers
I got the breather at O'Reilly's. It's very close to 1.5"-2". I just did some reading on pcv systems, and you should do a search on here. There's a lot of info. I just read that it's a better idea to run a full pcv system than to run a breather. I use a breather because my car is carbed.
RE: Breathers
I just measured my clearance and it's right about 1 1/2" at the tighest point. Can I check out O'Reilly's on-line. My other option is a baffle kit, but I'd rather not go that route, if I don't have to.
RE: Breathers
You should be able to check on-line, but going to the store would probably be better. It was just on the shelf in their little high performance section. I also just went and measured the breather...almost exactly 1.5" Pretty good guess i'd say.
RE: Breathers
i have no idea why breathers are illegal here in canada but i have had friends pulled over a ticketed for it. they can tow your car i beleieve or they can make you go to a special emisson safety place its really dum
