new headlights ? UPDATE W/ PICS
Old 01-14-2008, 05:10 PM
90lxstang
90lxstang's Avatar
Default new headlights ? UPDATE W/ PICS
i just got my new head lights from 50resto. they are the stock looking ones and i just wanted to know if you guys think i should drill holes in the bottom because one of my stock ones always had water in it and if so is there a particular place that i should drill the holes. thanks!
Edit: Pics towards the bottom.
90lxstang is offline
Old 01-14-2008, 05:50 PM
bobbyboura
bobbyboura's Avatar
Default RE: new headlights ?
no you shouldnt drill holes there are rubber seals that go bad where the bulb goes in replace thoes or put a small bead of silicone around the bulbs when you put them in
bobbyboura is offline
Old 01-14-2008, 06:57 PM
88blk5.0
88blk5.0's Avatar
If they start to fog up then send them back. Most aftermarket ones have a line of silicone on where the 2 peices of the headlight (lens and rear housing) connect with addition to the newer tighter weatherstripping. I wouldnt worry about them fogging up!
88blk5.0 is offline
Old 01-14-2008, 08:29 PM
djh1121
djh1121's Avatar
I didn't in mine and they are doing good for now... I love them.
djh1121 is offline
Old 01-14-2008, 09:06 PM
90lxstang
90lxstang's Avatar
It's not only them fogging up that I am worried about. The driver's side stock original would get condensation and/or pure water inside the lenses and it would sit within the headlight itself, eventually popping the light bulb if I happened to use it that night due to the bulb being hot. Any way I could keep water from building up inside the lenses? I can literally see the water line as if it were a fish bowl sometimes. Have aftermarket headlights taken care of this problem? Stockers are being replaced tomorrow.
Old 01-14-2008, 09:13 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I would put the new ones in first before drilling them. See how they work out.
PRO50SC is offline
Old 01-15-2008, 02:02 AM
P.S.I.cho
P.S.I.cho's Avatar
if the new ones leak set them on a wet piece of cardboard and bake them in the oven for a very short time to allow the silicone to get sticky, firmly press the lense and the back of the headlight together to seal them together and allow to cool, but new headlights shouldnt have a problem
P.S.I.cho is offline
Old 01-18-2008, 11:23 AM
90lxstang
90lxstang's Avatar
Here are some pics I took of the installation for those interested in doing this little project. Don't mind the broken side and bent fender, some jerkoff decided to slam into me and run away.
Before:
During:
After:
All that is left is to adjust the bulb angle, they point downwards a little too much. The job was pretty easy. Only tools required was a 7/16 wrench and a screwdriver. Took about an hour total, to remove the old headlights, clean up the housings and install the new headlights. I was surprised on how much better visibility was when I tried them out at night. I'd recommend these to anyone with faded stockers.
Old 01-18-2008, 11:30 AM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: new headlights ? UPDATE W/ PICS
ORIGINAL: 90lxstang
Instead of wasting your time and ruining a good set of NEW headlights, seal the seam where the clear portion and the backing of the headlight meet. Use CLEAR Flowable RTV that you can get at any auto parts store.
That will take care of the problem (water leakage) instead of just putting a bandaid.
Derf00 is offline
Old 01-18-2008, 11:38 AM
bighungrymatt
bighungrymatt's Avatar
I see a lot of X's
bighungrymatt is offline
Kenta08
09-02-2015 10:33 AM
svtrosey
SVT Forums
08-15-2015 09:09 PM
cricket
06-01-2005 10:53 PM
corder13
11-22-2004 09:36 PM
DaveG
05-26-2004 06:18 PM
Quick Reply: new headlights ? UPDATE W/ PICS
