Oil Pan Gasket??
Old 01-15-2008, 10:40 PM
MOhecan
MOhecan's Avatar
Default Oil Pan Gasket??
Been rebuilding my motor. the oil pan gasket i got is meatl plus i got the fel pro cork gasket. do i need to put both on or jus the meatl one on or do i need cork gaskets for the top and bottom with the metal one in between?
MOhecan is offline
Old 01-15-2008, 11:11 PM
Mustangkiler
Mustangkiler's Avatar
Default RE: Oil Pan Gasket??
Id get rid of both and use the rubber felpro one piece, im not entirely sure waht your saying, but with mine it was metal on the sides and front and back were rubber but you can replace the front and back with cork, do not stack gaskets on top of eachother.
Mustangkiler is offline
Old 01-15-2008, 11:46 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the metal one or what you deam it to be will be just fine...I believe you mean to say it's the one piece pan gasket reinforced with metal inside it to stiffen it
mjr46 is offline
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Oil Pan Gasket??
