coolant leak help
coolant leak help
alright guys im loosing coolant again and im trying to find out from which gasket. this time its the drivers side thats leaking. im wondering if i do a compression test and everything checks out does that mean it has to be the head to intake gasket or is there something else i should look for.
RE: coolant leak help
best way to find the leak is go to autozone and rent a coolant system pressure tester. it pressurizes the system and will force coolant out of where its leaking. it saves a lot of head aches trying to guess and running all those other tests
yes if its a head gasket you would have milky looking oil and your exhaust will be blowing lots of white smoke and smell really really bad you would def know it. as for finding out which cylender it is pull all the spark plugs and listen in each hole with a long screw driver for the air hissing out.
either way you need to start taking the engine apart to rebuild its more likely a head gasket so start with the intake if thats fine move to taking the heads off and replace those gaskets. just stop driving you can bend valves if you keep drving
yea i havent been driving it..just idleing...i took it fora short drive but nothing else. so if i do a compression test..and they all check out then it has to be the head to intake gasket right?
ORIGINAL: five0fm
