T5 Tranny
T5 Tranny
Should I switch from the t5 to a 6 speed tranny? Will I get better highway MPG or is there any advantages? I have no problems from the t5 but I do get ALOT of heat from the center console. I was thinking it was the tranny but the guy at the dealership said he didn't think it was coming from the tranny.
Any ideas on the heat would be a big help to. My engine temp was running high but I cutout the holes in my Cobra R hood and it helped alot. Its running a little high in the normal range.
RE: T5 Tranny
um no it isnt the trans. it is just coming in cause you have no insulation around the shifter from what i am guessing. and if you car is running a bit hot check your coolant level. get a new radiator aka aluminum at least a dual core, and a new thermostat.
RE: T5 Tranny
ORIGINAL: Mattangcobra95
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
