INJECTORS NOT WORKING HELP!!!!!
RE: INJECTORS NOT WORKING HELP!!!!!
You know, it would be of great help to those ofUS trying to help YOU if YOU would answer the questions WE have asked.
AGAIN, HAVE YOU VERIFIED THERE IS/IS NOTSPARK???
ORIGINAL: fishermanjesse
yeah well i took a spark plug out the heads and held it to the stut tower and it arc'ed
WILL THE CAR RUN ON CARB CLEANER OR ETHER? (ALREADY ASKED, NOT ANSWERED!)
What about compression, have you checked it?
ORIGINAL: PRO50SC
Were they wet at all, could you smell gas? Have you verfied the distributor is in correctly like mjr46 asked?
^^^^^....I think his head is spinning in circles right now cause he thinks he has done correctly everything we have mentioned...bet it's something simple that he has overlooked.and or one of the tests he is performing is being incorrectly done
k well i turned the crank damer to topo dead center, and set the distributor in so that the # spark plug was at the firing area is this right?:O my head is spinning circles havent tried the carb cleaner or ther yet its snowing here in NC and everyones freaking out OMG 1/2 inch of snow
