INJECTORS NOT WORKING HELP!!!!!
the wires are all good and i got a injector Noid the injectors are getting a pulse, i just upgraded to 42lbs since im running a 347w/NOS and got a 80mm MAF and the cars not getting fuel help, are the injectors just bad?
RE: INJECTORS NOT WORKING HELP!!!!!
From other posts I have seen in here,Yes you need to get it tuned. Those injectors seam a bit on the hight side. Also do you have the fuel pump to feed thought injectors?
so did you try spraying some ether in the throtle body and see if it fires up no confirm a no fuel issue??? does the pump run when turning the ignition on for a few sec?? do you have fuel pressure??
ORIGINAL: fishermanjesse
yes i have about 45psi of fuel pressure, i dont even hear the injectors clicking with a screw driver
Again, try to start it on starting fluid or carb cleaner. If it fires, it's a fuel issue. Have you verified there is spark? Is the maf calibrated for the 42's?
Did you confirm spark at the plugs?
Check your plugs to see if they are wet of flooded.
What else did you change?
Was the car running before you worked on it?
Maybe you left something unplugged.
If you installed a new throttle body you need to crank the throttle plate stop screw open a few turns to get more air for it to start and then adjust it (properly)after it's warmed up.
Did you try holding the throttle open when starting it?
