94 wiring problems
Old 01-20-2008, 01:22 PM
cougarfan088
cougarfan088's Avatar
Default 94 wiring problems
the headlights and the radio dont work, there are wires hanging down from under the steering wheel and i dont know what to do.. everythnig else works fine..what should i do? the person i bought it from said they had some keyless starter or entry thing put in but i dunno if that ha snaything to do with it becasue that doesnt work eather.
cougarfan088 is offline
Old 01-20-2008, 01:36 PM
fourfivefour
fourfivefour's Avatar
Default RE: 94 wiring problems
The wires are most likely from the alarm. Check your fuses.
fourfivefour is offline
Old 01-20-2008, 02:32 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
most likely the alarm was tapped into the headlight circuit to flash the lights in the event of an unauthorized entry...you'll need to look under there and see if you can see wires that were cut that need to be rejoined...or get the appropriate diagram and trace the circuit and wire colors and make sure none are cut
mjr46 is offline
Old 01-20-2008, 11:23 PM
cougarfan088
ok, ya there is definately some wires cut so ill see what i can do.
2007StangV6
01-28-2016 06:09 PM
Doogie65
09-06-2015 02:55 PM
zanemoseley
09-06-2015 12:58 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: 94 wiring problems
