Did I screw up MAF?
Old 01-20-2008, 09:45 PM
steve10TX
steve10TX's Avatar
Default Did I screw up MAF?
I just bought this car a little over a week ago. I've been slowly going over everything to find out what I've really got. The car was running good before I worked on it theis weekend. I replaced the electric water pump on the intercooler and decided to clean the K&N filter. Since the car is supercharged, the MAF/filter is in the fender well. It was a pain to get out. I cleaned the filter like I always clean my other K&N's...let it dry 24 hrs, then oil, let dry out in sun ~3 hrs. The MAF is a Pro Flow 77mm...looked clean, was careful to cover it on the workbench overnight. During the process of getting everything back in the fender and hooked up, I know it got bumped pretty good, not sure if that could hurt it. When I started the car it was putting out a ton of smoke that would burn your eyes, and stumbling, popping, finally died.
I'm thinking it has to be the MAF, since I didn't mess with anything else. Does it hurt to plug/unplug the meter? Any reset procedure? I did have the ignition turned on a few times with it unplugged to check the electric water pump operation.
Any help? I've been away from Mustangs for awhile, guess I better jump back in with a problem to start.
steve10TX is offline
Old 01-20-2008, 11:06 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Did I screw up MAF?
pull the MAF out, spray some maf cleaner through it, and try again without the filter installed.... you might have gotten some K&N oil on it
AdderMk2 is offline
Old 01-20-2008, 11:23 PM
94 G STANG
94 G STANG's Avatar
hey addster where have you been man ?
94 G STANG is offline
Old 01-20-2008, 11:39 PM
AdderMk2
Banned
AdderMk2's Avatar
ive been dead
AdderMk2 is offline
Old 01-21-2008, 12:24 AM
steve10TX
steve10TX's Avatar
Thanks, I'll try that first thing in the morning. Only other thing I can think of is a stuck injector. Any idea on the best way to test?
Old 01-21-2008, 12:42 AM
94 G STANG
94 G STANG's Avatar
well its good to have your sarcastic annoying a$$ back
Old 01-21-2008, 02:30 AM
lxman1
lxman1's Avatar
I've replaced two ECM's on 2 differnt Fords this year for a bad injector driver. It will go wide open and dump fuel down into the cylinder. You would need a noid light to see if this is true. The injector plug should give you a pulse when running. The ones that I found had the noid light lit up like a headlight.
It should idle somewhat with the MAF unplugged to see if the black smoke goes away. They usually default to lean when bad though. It's not installed backwards is it?
lxman1 is offline
jwog666
12-27-2021 08:09 PM
piotrek53
10-13-2015 06:54 PM
breaking
10-02-2015 01:27 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: Did I screw up MAF?
