brake ?
Old 01-21-2008, 06:12 PM
86stanglx
86stanglx's Avatar
Default brake ?
on a 88 coupe with 4 inchwheels in front and factory drums in the rear and stock power brake setup, do i need a adjustable proportioning valve?
86stanglx is offline
Old 01-21-2008, 06:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: brake ?
no not really..I have skinnies in the front and fattys in the rear and it stops just fine...you could however add one for extra benifit if desired
mjr46 is offline
Old 01-22-2008, 04:57 AM
86stanglx
86stanglx's Avatar
Default RE: brake ?
thanks thats what i was wondering because im getting the brake lines put in now
Old 01-22-2008, 06:50 AM
mjr46
mjr46's Avatar
Default RE: brake ?
ORIGINAL: 86stanglx
but you do heed what is called the distribution block in there...it's the little brass thing attached to the lower front left frame rail that all the lines go into so in the event of a failure on one circuit it'll shut of hydraulic pressure to that circuit
mjr46 is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: brake ?
