I need your expertise
-1994 5.0 H/O
Firstly it is very cold outside seems how it is winter in New York State. But I am having some very out of the ordinary problems with the mustang. Before you say any of these I already put in a new distributor cap, rotor, stator, spark plugs, fuel filter, engine coolant sensor, ignition module and checked the fuel pressure and yes I can hear the fuel pump. Somewhere between putting the stator in and and doing the timing it started! It would idle fine and I thought I was good to go. Turns out I was very wrong I brought the car home and put it in the driveway and woke up today to try an start it and it would just sit there turning over same problem I had before. Then I made sure to mark the distributor and turned the distributor cap clockwise a little bit turned the key she fired right up. I turned it back to where I marked it and it would idle there just fine (10 degrees). I brought it out on the road and shut it off and then again it wouldnt start up.. What is going on here??
RE: I need your expertise
Sounds like you dont have the timing set right. been a long time since i did timing on a car but when you checked the timing did you pulla tab out? It should be near the distributor i believe.
