what bore?
Old 01-21-2008, 10:40 PM
855.0sean
855.0sean's Avatar
Default what bore?
what would be the best bore for my 5.0?
its a carbed 85 5.0 with 83000 miles on it.
855.0sean is offline
Old 01-22-2008, 07:44 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: what bore?
take it to the machine shop...it may just need a hone ..if not then standard would be .030
mjr46 is offline
Old 01-22-2008, 03:42 PM
WLingle92lx
WLingle92lx's Avatar
It would probably only need a hone if its an 80K block that was taken care of.
If you bore it, it will give you a little more compression but then you would have to buy 0.030 over pistons. Boring my block 0.030 over took my compression from 12.0.1 to 12.2.1, not much but its some.
WLingle92lx is offline
Old 01-22-2008, 08:03 PM
tinman
tinman's Avatar
If car is still on a carb (hope so) there could be some egg shaped wear in the cylinders.
If that is the case then .030 is the next overbore size.
That would make it a 306..........
tinman is offline
Old 01-23-2008, 09:17 PM
855.0sean
855.0sean's Avatar
hes redoing everything for me including the entire engine rebuild for 1200. i was told it would be another 50-75 horespower with a more aggresive cam.
Old 01-23-2008, 09:59 PM
89Ford
89Ford's Avatar
boring an engine cylinder doesnt really add any power, so 4.000 but if you have to .030 over is second best
89Ford is offline
Old 01-23-2008, 10:16 PM
mjr46
mjr46's Avatar
ORIGINAL: 855.0sean
bwah haaaaaaaaaaaaaaaa.......and you believed him???? maybe with a good set of aluminum heads good intake and supporting mods it might generate an extra 75 rwhp..but with just a cam???[sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif]
mjr46 is offline
Old 01-23-2008, 11:03 PM
855.0sean
855.0sean's Avatar
no not just the cam performance heads, pistons,bearings alot of other stuff.
ill call him and get a list. its a performance kit from nelson racing i believe? not100% sure what brand but i think he said nelson?
Old 01-23-2008, 11:05 PM
855.0sean
855.0sean's Avatar
nevermind not nelson ill find out tommarow though.
Old 01-23-2008, 11:12 PM
mjr46
mjr46's Avatar
what heads???and intake?? and size cam??
mjr46 is offline
Quick Reply: what bore?
