Rotor HELP!!!! WITH PICS
So here is my story. I bought rotors from one store which came out to $165 for the pair. I went to another store and bought another set of rotors because they were $134 and $20 off that. So here is my problem. I took both pairs out of the boxes to compare. Well the ones I paid $165 for look MUCH better. So not only do they look better but the actual size of them are much bigger. I measured the ones that I paid $165 for and they were 10 inches 7/8" long. The other ones were 10 inches long.
[The one on the left is the cheaper one, and the right one is the more expensive one]
I also measured the wall thickness and the cheaper set was 13/16" thick and the more expensive ones were 1" thick.
[Cheap set is on the left and the expensive ones are on the right]
I looked at the height of the two from where the lug nuts go to the actual surface starts and you can see the height difference.
More or less the offset of the two. It is hard to explain, if someone needs a better explanation please let me know!
[The one on the left is the cheap one and the one on the right is the expensive one]
So my question is which one would you guys chose, and also will they both fit? I would like to keep the more expensive ones as they look much stronger, but I am not sure if they will fit. Will the larger rotors fit on my car or not?
Here are some other pictures of the two rotors.
Both rotors together
Cheaper rotors
Expensive rotors
Car is a 1988 GT
Cheaper rotors
Expensive rotors
Car is a 1988 GT
RE: Rotor HELP!!!!
ORIGINAL: 67mustang302
One of those rotors is the wrong one. The Caliper's size and mounting location will only allow 1 certain size of rotor to be used.
RE: Rotor HELP!!!!
How did you end up w/ 2 different sized rotors? Maybe the smaller one is for a 4 cylinder car. Take a measurment of your car and then you'll be sure which one you need. I would suspect it's going to be the larger of the two.
RE: Rotor HELP!!!!
ORIGINAL: PRO50SC
The ones from canadian tire are larger then the ones from parts source. Hope that cleared it up
RE: Rotor HELP!!!!
ORIGINAL: 88sirneedsalot
lol why did you buy them from diffrent places i cant figure that out ?
I then noticed Parts source had there rotors/drums for 15% off and my dad had coupons for save $10.
I went to Parts source to get a quote and they quoted me $135, so I figured they were much cheaper.
When I phoned parts source now, they told me that the rotors for my car were $91 each. So either way its the same.
I am just going to return the crappy 4 banger ones and keep the ones I already have.
Thanks for everyones help....especially PRO....your always great with helping others out.
p.s parts source shouldn't hire ladies to do this type of stuff [:@][:@][:@][:@][:@]
