86 fox battery wont charge - MustangForums.com
Old 03-25-2005, 11:51 PM   #1
pacepony
Default 86 fox battery wont charge
i have a 86 mustang and the battery will not charge. the battery is good but i cant get power from the alternator to the battery. where is the voltage regulator and where should he wire from the alternator run to?
pacepony is offline   Reply With Quote
Old 03-26-2005, 12:09 AM   #2
86HOGT
86HOGT's Avatar
Default RE: 86 fox battery wont charge
It's an internal regulator, if you check the voltage while the car is running, and it's too low, replace the alternator.
86HOGT is offline   Reply With Quote
Old 03-26-2005, 12:15 AM   #3
pacepony
the alternator is putting out 12.8 volts but i dont know if it is gettin to the battery. is it a straight wire from the alternator to the solinoid, could i just run a new wire coming from the alternator?
Old 03-26-2005, 12:21 AM   #4
horatio102
12.8 isn't enough. While running it should charge at about 14 volts. Pull it out and take it to an auto parts store and have them test it.
horatio102 is offline   Reply With Quote
Old 03-26-2005, 12:58 AM   #5
pacepony
where does the wire from the alternator go? so i can check if it getting to the battery
Old 03-26-2005, 01:28 AM   #6
horatio102
hm. Have you had any work done recently? Check to make sure you've got good ground connections from the alternator to the block, block to body, and battery to body. In my truck I run the main ground directly to the block.
Old 03-26-2005, 01:58 AM   #7
pacepony
i just bought the car and i trying to get it fixed
Old 03-26-2005, 02:16 AM   #8
horatio102
I'd make sure the negative battery terminal has a good connection to the block and chassis.
Old 03-26-2005, 02:23 AM   #9
BigMg
You have three wires going to alt? or 4? also the big wire is the feed wire to the bat the wire is direct to the solinoid. and the reason that you had 12.8 volts at that wire is because that is system voltage from the bat (current flows both ways ,(remember)) My guess if you have good grounds and you other wires going to the alt are ok then it is the alt. get it tested...............
Good luck,
BigMg
BigMg is offline   Reply With Quote
Old 03-26-2005, 04:55 AM   #10
FiveOhNo
have you not checked the battery with the car running yet (actually checked it at the battery)? if it's a new battery and the voltage is low, it's more than likely the alt.
FiveOhNo is offline   Reply With Quote
Vintage AC shop referral - frontrunner serpentine system bradleyb Classic Mustangs (Tech) 3 11-27-2015 07:50 PM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:29 AM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 01:02 AM
Engine Knock 69Volunteer Classic Mustang General Discussion 1 09-30-2015 10:39 AM
Hello All RCS02v6 New Member Area 4 09-29-2015 01:46 PM
1986, 50, 86, alternator, battery, car, charge, ford, fox, gt, location, mustang, terminals, wire, wont
