nos
Old 10-06-2003, 05:18 PM
86convert
86convert's Avatar
Default nos
hi i have a 86 5.0 convertible. it has some small mods but i just purchased nos for it. i want to go with a 125 shot on my bone stock bottom end. do you think i need to do anything or will i be safe with that. i really dont want to spank my motor i want to spank some chevys. thanks
86convert is offline
Old 10-06-2003, 05:54 PM
allblack
allblack's Avatar
Default nos
thats a big s**t for a stock engine if i were to put noz or zex on my mustang i woundnt go anything bigger than a 75 shot.
allblack is offline
Old 10-06-2003, 06:14 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Default nos
Aren't the 86's forged pistons? I think the compression is higher due to no valve reliefs though. 125 is fine on most any motor, but you will need to do some tuning to prevent detonation.
mdvaldosta is offline
Old 10-06-2003, 10:11 PM
T5superduty
T5superduty's Avatar
Default nos
its nitrous!
T5superduty is offline
Old 10-07-2003, 12:48 AM
95Stealth302
95Stealth302's Avatar
Default nos
Thanks again T5 for your insightful commentation. Anyway, I agree that with the forged pistons will hold up well, but 125 is still pretty high taking into account the fact that your engine may have a lot of miles on it, but then again I dont know all you've done to it. Nitrous wont just affect your block and bottom end if all the other parts are getting older.
95Stealth302 is offline
Old 10-07-2003, 03:11 AM
84stang
84stang's Avatar
Default nos
Before i built my new my motor, i had an 86 wiith the true forged flat tops and the heads with the heart shaped valves(they suck). But i started with a 125 shot and it handled it with ease for atleast 20 runs at the track. After ahwile i decided it was time to build a motor with Aluminum heads and a bulletproof bottom end to hold to the nitrous.(It now holds up to a supercharger). So i decided to jet the nitrous up to a 225 shot for the motor's grand finale. Surprisingly enough it held up first run on the track. The second run i threw a rod and the block is no more. So yes in my opinion a 125 shot should be fine on that block.<edited><editID>84stang</editID><editDate>37901.0517939815</editDate></edited>
84stang is offline
Old 10-09-2003, 01:13 AM
mrfordgt91
mrfordgt91's Avatar
Default nos
a 125 shot is a good choice for you. if you want to be safe about it get a retard box for it to prevent detonation. other than that you should be safe.
mrfordgt91 is offline
Old 10-09-2003, 01:19 AM
Redline5th
Redline5th's Avatar
Default nos
NAWSS!!!!!!! NAWWWWWWWWWWWWW</P>
SSSSSSSSSSSSSSSSSSSSSS!!!!!!!! NAWNANNAWWWWWSSSSSSSS!!!!!!</P>
NAAWWWWWWWWWWSSSSSSSSSS!!!!!! NAAAAAAAAAAAAAAAAWWWWWWW</P>
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW</P>
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWSSSSSSSSSSSS</P>
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SS</P>
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! nos nos nosnosnosnosnosnosnosnosnosnosnosnosnosnosnosnosno snosnosnosnosno</P>
So guys what's wrong with the above ^^^?</P><edited><editID>Redline5th</editID><editDate>37902.972974537</editDate></edited>
Redline5th is offline
Old 10-09-2003, 02:22 AM
slidewayz94
slidewayz94's Avatar
Default nos
If u go the 125 shot use two steps colder than stock plugs. Ford has them. And retard your timing accordingly. experiment with 75 then move up.</P>
slidewayz94 is offline
Old 10-12-2003, 09:33 PM
Mustang88LXKid
Mustang88LXKid's Avatar
Default nos
</P>
thats right its nitrous everyone! nos is fast and furious junk.....</P>
Mustang88LXKid is offline
Quick Reply: nos
