z303 ptv clearance question
Old 01-28-2008, 02:07 PM
87lxBlackWidow
87lxBlackWidow's Avatar
Default z303 ptv clearance question
anybody have this cam with stock heads and 1.6 rr's?? any PTV clearance problems?
87lxBlackWidow is offline
Old 01-28-2008, 02:16 PM
w8less
w8less's Avatar
Default RE: z303 ptv clearance question
that cam i way too much for stock heads and yes you will have ptv problems
w8less is offline
Old 01-28-2008, 02:24 PM
87lxBlackWidow
whats the biggest lift these stock heads are good for?
Old 01-28-2008, 02:29 PM
w8less
w8less's Avatar
its not really the heads, well to a point it is a head. the heads are resrictive so putting a massive cam in it will, and can make it slower than it was with the stock cam.
i suggest finding another cam
w8less is offline
Old 01-28-2008, 02:42 PM
87lxBlackWidow
even if i have an edelbrock rpm upper and lower with 70mm MA and TB? ... i currently have the f303 in the stang and was given a brand new z303 for free so i was figguring why not swap em out.
here is where my problem is... i have 2 other friends in my club that have ran this z-cam before and they claim theve never had the clearance problem before so im torn on who to believe... anyone else out there have 2cents to put in?
Old 01-28-2008, 03:03 PM
5spd GT
5spd GT's Avatar
Piston to valve clearance can vary from engine to engine, slightly.
If you have two friends that have ran the "Z" cam, how about ask them why they are not running it anymore
That camshaft is just not a good match for those highly limiting heads.
Technically, if they did not have issues, you may not have clearance issues, assuming they were running stock pistons, heads, as well.
One thing for sure, I would get some better springs and valvetrain to match.
Z303 - 228*/228* - 290*/290* - .552"/.552" - .345"/.345" - 112* - 107*/117* - Up to 6,500
Overlap: 66 degrees.
1.6 Rocker Ratio
Intake Opening: 7* BTDC
Intake Closing: 41* ABDC
Exhaust Opening: 51* BBDC
Exhaust Closing: 3* BTDC
5spd GT is offline
Old 01-28-2008, 03:23 PM
87lxBlackWidow
you make a good point 5spd... they both had stock heads and piston (93 stock block's) like mine.but now mybuddy keith is running a 351 now and dave got a trickflow stroker kit with the cam the kit came with... thats why they are no longer running that cam.
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: z303 ptv clearance question
