CAI vs. FIPK
CAI vs. FIPK
Is the CAI way better than the K&N FIPK? I have the FIPK for my stang which just sits in the engine bay where the old air box went. I payed like 140 for it and I think I'm regretting that. Also, if I want to get a bigger MAF, will I have to change out the CAI or FIPK, or does it fit like stock?
CAI vs. FIPK
I've read numerous places that if you change out the MAF, it is recalibrated for certain injectors. Just make sure that it will work with your injectors, 19lb stock i believe.<img border="0" src=smileys/smiley2.gif border="0">
CAI vs. FIPK
I have both for my '95. I don't really notice a difference between the two, just that the CAI looks nicer (it's chrome) and doesn't pull air in directly from the engine compartment like the FIPK. Also I have an 80mm MAF...and I got the FIPK to work on it by using a black stove pipe cap (6 in. daimeter) it's not as thick as the k&n base plate but it works well enough. Just drilled out 4 holes for bolts and the big hole for the MAF itself.
junior04
09-28-2015 10:53 AM
