Thermostat
Old 01-31-2008, 02:18 PM
92cobra
92cobra's Avatar
Default RE: Thermostat
I personally wasn't going to do it. I was just gonna pay a mechanic that I know who lives right next door to me 20 bucks to do it. I don't know if it will fix the situation or not, however its a good start in my eyes. After this, I will be taking it to a shop to have diagnositcs done.
Thanks for your input guys.
92cobra is offline
Old 01-31-2008, 02:21 PM
bighungrymatt
bighungrymatt's Avatar
good luck let us know how it goes
bighungrymatt is offline
Old 01-31-2008, 02:33 PM
92cobra
92cobra's Avatar
thanks matt, i most certainly will. I planned on having it done today, but im reschedueling for tomorrow since i over slept. Although i only got 2hrs of sleep, but thats besides the point haha.
I really hope this fixes my issue because its killing me getting 190-200 to a tank instead of 280-320. Killing me I tell you, killing me!!!
If you have any other ideas, let me know. Example o2 sensors, however those are newer, ECT "engine coolant tempature" sensor, which could be bad causing me to run in open/closed loop the entire time, thermostat, etc.
Dunno, but I need to find the solution, and I dont want to pay a shop 70 bucks for diagnositcs to find a "possible" solution.
92cobra is offline
Old 01-31-2008, 05:03 PM
1985stang
1985stang's Avatar
I doubt it's because your t-stat is bad man. It's because it is SOOO cold. It isn't warming up because when you drive, even very slowly, it's blowing ice cold air through your radiator. I have a mechanical autometer temp gauge, it will only start registering when it's this cold after about 10-15 minutes of idling (which is 120 degrees). If i don't move at all it will slowly rise up to 180 ish, then if i move at all it will slowly lower.
1985stang is offline
Old 01-31-2008, 05:05 PM
Albizo66
Albizo66's Avatar
yeah mine, in this cold weather, usually jsut gets to 150...in warmer temps it goes to 180
Albizo66 is offline
Old 01-31-2008, 05:29 PM
1985stang
1985stang's Avatar
ORIGINAL: Albizo66
Yep, that's about it for me too, 140-150. It's just unbelievably cold here, so don't worry about anything yet.
Old 01-31-2008, 06:25 PM
92cobra
92cobra's Avatar
what kind of gas milage are you guys seeing though with this extremely cold weather?
By the way, is the snow hitting you too 1985stang, because were expecting 3-5 inches lol.
92cobra is offline
Old 01-31-2008, 09:36 PM
Jfsram
Jfsram's Avatar
ORIGINAL: 1985stang
The job of the thermostat is to close the radiator out of the cooling loop until it reaches operating temperature.
I have luke warm air from my heater in 4 minutes and can reach normal operating temp in 10-15min. Regardless of the temperature outside.
Jfsram is offline
Old 01-31-2008, 10:18 PM
lxman1
lxman1's Avatar
Yep, if the thermostat is working properly, it will warm up and stay at the set point of the thermostat. Regardless of outside temp. @ 5 degrees outside, mine runs 192 to 195 idling or 75mph.
lxman1 is offline
Old 01-31-2008, 10:57 PM
m_ross05
m_ross05's Avatar
Will the temp of the coolant really make it not go into closed loop? I dont know in OBD1 Fords but in OBD2 chevys all that has to do is the o2 sensors to warm up to a certain point and then it will go into closed loop....I have seen them go into closed loop within 5 mins with 160 tstats
m_ross05 is offline
Quick Reply: Thermostat
