Thermostat
#32
RE: Thermostat
ORIGINAL: aode06
The first mistake here, is relying on your dashboard reading, when in fact you could have a bad Temperature Control Sending Unit.
If you have heat, leave the thermostat alone, as you are about the open a can of worms.
#33
RE: Thermostat
280 is WAY to hot!...the tstat is probably not opening and is stuck shut. Take it out, and put a new one in immediately. Whenever you buy a tstat, put it in boiling water to make sure it opens.
Dont listen to what other people say, trust me when i tell you it WILL open, spring loaded or not, it will open. Tstats are based on tempature of coolant, not pressure all pressure.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
