What size injectors will I need?
Old 02-03-2008, 01:09 PM
94gtbuilder
94gtbuilder's Avatar
Default RE: What size injectors will I need?
Ok 42 it is then unless there are further objections?
94gtbuilder is offline
Old 02-03-2008, 01:47 PM
5spd GT
5spd GT's Avatar
What engine modifications do you have?
How can we tell you are actually going to run 400 HP at the engine?
30 lb injectors will be just fine for 400 HP at the engine, N/A.
5spd GT is offline
Old 02-03-2008, 02:34 PM
94gtbuilder
Stoke 302 to 347, Trickflow perf kit, MAF, Cold Air, Exaust, Etc, and maybe a supercharger down the road, and it will be tuned.
Old 02-03-2008, 03:08 PM
nmerrill
nmerrill's Avatar
Did noone read the stickies??? I posted a link. Use the calculator
copied straight outta the link i posted:
Here is a good formula to find out what size injectors you need
(H*B) / (C*D)= estimated injector size
H=horsepower (Rear wheel)
B=*B.S.F.C. (see below)***
C=number of cylinders
D=duty cycle (constant .80-.85)
B.S.F.C.=
Low to med. performance = .50
Performance engine with head work= .45
High performance with lots of head work= .40-.45
S/C or T/C engines= .55-.60
So, according to the calculator, you would need 28.125 injectors, or 30#. If you plan on supercharging dont even waste your time with the 30's, and step up to AT LEAST 42's. But at that point the best fuel system in the world isnt gonna keep your block from splitting down the middle
nmerrill is offline
Old 02-04-2008, 04:49 PM
94gtbuilder
I dont think I will supercharge anyway. It was just a thought. Soo, id be safe with the 30# injectors then with a little extra. Objections?
Old 02-04-2008, 06:03 PM
94gtbuilder
yo
Old 02-04-2008, 08:42 PM
Tims 88GT
Tims 88GT's Avatar
42# you will want more power anyway. and 30# are going to be in a major duty cycle with 400hp
Tims 88GT is offline
mltdwn12
09-23-2015 08:54 AM
Demodulates
09-18-2015 11:14 AM
pimp2303
09-17-2015 08:45 PM
uedlose
09-10-2015 01:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: What size injectors will I need?
