Which Heads Are Better ?
Old 02-03-2008, 10:46 AM
Explosive
Moderator
Explosive's Avatar
Default Which Heads Are Better ?
My dad said he was looking at heads and he said edlebrock has slightly higher numbers than AFR. We were looking at AFR originally. So my question is, which are better Edlebrock or AFR heads ?
Explosive is offline
Old 02-03-2008, 10:49 AM
my77stang
my77stang's Avatar
Default RE: Which Heads Are Better ?
i heard the new edelbrock 170's flow as good as the AFR 185's.... if thats true then i'd go with the edelbrocks
my77stang is offline
Old 02-03-2008, 11:26 AM
Joel5.0
Joel5.0's Avatar
If your Dad is looking into buying a set of heads based only on advertised flow tables....... suggest he looks again. There are other items/characteristics he should also check........ like valve train quality for the intended application.
Joel5.0 is offline
Old 02-03-2008, 11:34 AM
nitrous_bob
nitrous_bob's Avatar
well depending on price...i'd get the cheaper heads then do a little port work
i would never put a set of heads on a car box stock, there is too much to be gained afor little $$$$$$
small block ford heads lack exhaust flow , and at minimum need porting there. not 1 single head made for the 5.0 isoptimum from the box
nitrous_bob is offline
Old 02-03-2008, 11:45 AM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: nitrous_bob
that might be true but some are a lot better off than others.
OnyxCobra is offline
Old 02-03-2008, 11:51 AM
PJC Racing
PJC Racing's Avatar
ORIGINAL: Joel5.0
Very true. I have had 2 sets of Edelbrock heads and both of them had valve train parts issues in quality and assembly.
PJC Racing is offline
Old 02-03-2008, 12:09 PM
thunderjet429
thunderjet429's Avatar
i would never buy a set of heads because ons companies flow bench shows better than anothers.. to many variables there, the only way to be sure is test both on the same bench.... i have dart pro1's 195cchad my friend port them and put 2.05 valves in them and now they outflow brodix track 1's.... but that does you no good if tou don't have the rest of the package.
thunderjet429 is offline
Old 02-03-2008, 12:56 PM
w8less
w8less's Avatar
dont race flow benches hey all flow differently
ORIGINAL: OnyxCobra
i have just learned how really true this is
w8less is offline
Old 02-03-2008, 12:57 PM
w8less
w8less's Avatar
if you want awesome heads out of the box check these out
w8less is offline
Old 02-03-2008, 01:01 PM
PJC Racing
PJC Racing's Avatar
ORIGINAL: Jasperstang308
I agree, you can bet the house that the parts installed are quality and they are assembled correctly.
Edit: Let me clarify my statement: If you get the heads from CI you can guarantee the heads have been gone through and the correct parts have been installed.
Quick Reply: Which Heads Are Better ?
