i go tmy new 94 gt and i need help
Old 02-03-2008, 09:10 PM
5.0 85 GT
5.0 85 GT's Avatar
Default i go tmy new 94 gt and i need help
hey, i traded my white 5.0 and cash for a bright atlantic blue 94 gt, my dream car..but the car overheats instantly, after 10 min of drving, it smokes and overheats, the sensor says low coolant even tho its full. Could it be a thermostat? also i checked the radiator fluid, it was all white and milky which i think is part of the problem.
Now heres my next question, the car has 147k on the orig 5.0, could eb rebuilt not sure, car ahs some bals, has full exhasut and a cai and chip. I want a kenne bell very badly, should i charge this 5.0 and go for broke, or go for my real dream and drop in a 03 cobra motor tranny and interior on this car? let me know thanks guys..
5.0 85 GT is offline
Old 02-03-2008, 09:15 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: i go tmy new 94 gt and i need help
if you got oil in the coolant...you most likely have a blown head gasket, or I've even seen a water pump implode on a 94 gt and knick a small hole in the timing cover but in that case you'd have coolant in the oil not the other way around
mjr46 is offline
Old 02-03-2008, 09:31 PM
racin66coupe
racin66coupe's Avatar
do the 03 cobra engine/interior!!
racin66coupe is offline
Old 02-03-2008, 09:34 PM
5.0 85 GT
5.0 85 GT's Avatar
ok so am i ruining my motor/car by driving it with it liek that? i got a little nervous when i saw thrat? should i drain the coolant radiotor and poour new stuff in?
Old 02-03-2008, 09:38 PM
mjr46
mjr46's Avatar
if it in fact is getting oil in the coolant....your not doing any good by running it and if it's salvagable and you keep doing that then eventually by overheating it.it will be a total loss.. and by draining the coolant if in fact the head gasket is blown will be a waste of time and money
mjr46 is offline
Old 02-03-2008, 09:41 PM
5.0 85 GT
5.0 85 GT's Avatar
ok next question, the color of the stuff int he radiator is white and soupy looking, almost looks liek blown head gasket sealeant, where do you pour that stuff in? idk im pissed off what do you suggest i do? also how much would it cost to fix a blown head gasket? thanks for your time
bluovalguy
08-24-2015 08:20 AM
Steve@CJPP
CJ Pony Parts
12-05-2012 11:59 AM
Steve@CJPP
CJ Pony Parts
04-19-2012 03:28 PM
Steve@CJPP
CJ Pony Parts
04-13-2012 02:53 PM
Steve@CJPP
CJ Pony Parts
03-30-2012 03:06 PM
Quick Reply: i go tmy new 94 gt and i need help
