400whp
Old 02-06-2008, 09:52 PM
Albizo66
Albizo66's Avatar
Default RE: 400whp
ORIGINAL: Alero99
sounds like you need a top mount s/c
instant boost, torque curve flatter then a pre pubercated girls' chest
crusing it makes little if any noise at all...
ahhhhhhhhhhhhhhhh hahahahahahahah
Albizo66 is offline
Old 02-06-2008, 11:05 PM
zash
zash's Avatar
Default RE: 400whp
ORIGINAL: Alero99
yeah, that's exaclty what I'm looking for (not the girl!).
So after a search on the web Kenne Bell popped up. Best choice or are there better (value wise)?
zash is offline
Old 02-06-2008, 11:09 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: 400whp
ORIGINAL: Alero99
yeah that made me lol.
As for quiet forms of boost, turbos don't make any noise until they spool and then it sounds like a jet engine, which is awesome. Kenne bells only whine under boost, other than that they are silent. Some Vortechs are quiet also, not too familiar with those.
OnyxCobra is offline
Old 02-06-2008, 11:12 PM
r.barn
r.barn's Avatar
Default RE: 400whp
Trust me you want a nice single turbo kit.
Will make more power than KB for same money.
Turbo is quiter than an s/c because exhaust has to
pass thru turbo.
You can have the blow off valve exhaust into
intake before turbos and you wont here it.
Turbo will have just as much torque off the line
and will come with intercooler.
r.barn is offline
Old 02-06-2008, 11:29 PM
zash
zash's Avatar
Default RE: 400whp
ORIGINAL: Mustangkiler
the reason you hear the blow off valve more on a turbo car is because its released out in the atmosphere while superchargers got bypass, does teh same absic thing just recirculates it through the intake and back through the supercharger thats why its much quieter, my kb isnt a loud whine at all at 10psi and below.
Ok, KB is Kenne Bell. Got it now :-) So the stock auto tranny is taking the abuse? Or did you mod it? What power are you getting with your setup (on pump gas)?
zash is offline
Old 02-06-2008, 11:32 PM
zash
zash's Avatar
Default RE: 400whp
ORIGINAL: r.barn
pass thru turbo.
Do you recommend a particular kit?
zash is offline
Old 02-06-2008, 11:33 PM
Mustangkiler
Mustangkiler's Avatar
Default RE: 400whp
Its taking it suprisingly, at 10 psi stock pump gas 350+ lbs of torque at 3000 rpm at the wheels on a stock 5.0 engine through an auto ive yet to see a turbo beat that. Blowzilla kit, Flowzilla if you plan on putting it on a stroker.
Mustangkiler is offline
Old 02-06-2008, 11:37 PM
92cobra
92cobra's Avatar
Default RE: 400whp
+1 on going turbo instead of supercharged. You will get annoyed by the whine very quickly from it, trust me. The turbo can be made to be very very quite, and is cheaper and easier to produce more power with. A simple single turbo setup will do you very well.
92cobra is offline
Old 02-06-2008, 11:46 PM
bighungrymatt
bighungrymatt's Avatar
Default RE: 400whp
I cant hear my procharger when I get on it
bighungrymatt is offline
Old 02-06-2008, 11:48 PM
Alero99
Alero99's Avatar
Default RE: 400whp
Each set up has its ups and downs
Turbos are typically very expensive for the average joe, tuning becomes issues, and day to day reliablility, ALOT of piping running a muck in your engine bay, boost leaks, intercooler problems, blah blah blah
Top Mount S/Cs are slightly less expensive and much more simple,
TURBOS WILL ALMOST ALWAYS OUT PERFORM A S/C REMEMBER THAT!
but for street use, def get the top mount S/C, slap a Whipple, Kenne Bell, or a WEIAND on there
Alero99 is offline
Quick Reply: 400whp
