steering problems??????
when im driving doesnt matter wat gear im in or what speed....the car drifts all over the road....when im on the highway and hit a bump i can hear a knock under the driver side floor board like somethings loose.....PLEASE HELP!!!
thanks all!!
1995 5.0 cobra
bbk headers
flowmaster off road racing exhaust
3.73 gears
thanks all!!
1995 5.0 cobra
bbk headers
3.73 gears
RE: steering problems??????
Put it on jackstands and get under there and make sure there is nothing lose. I would not be driving till you get if fixed. It could be a number of things, but all of them include getting under there and checking it out.
well I dont know exactly what to say or do but I have sloppy steering in my 94 GT so I replaced some of my bushings in my steering rack and im going to replace my power-steering pump. You can get and replace the bushings pretty easily. As for the knock i dont know enough about that. How many miles are on your car?
yea i have play in my wheel and my car drifts too. most of the time its tie rods or bushings.. could be as simple as an alignment though too. i had skinnies on the front and had no problem but then i put wider tires on there(9 inch) and it pulls all over the road. is the car lowered? uneven tire wear? could be alot of things
ORIGINAL: 92cobra
im gonna say you have a broken tie rod end. Jack the car up and wiggle the tires and see if they move in/out or up/down. let us know buddy.
[align=left]
also another problem that I have seen on my sn95 is the lower steering shaft where it meets the rack will go out check the black rubber <its almost like a slip> for play. Unfortunatly not going to make a loud noise like you have.
ORIGINAL: c4king
[/align]
^^^^^^yep^^^^^ check your tie rods also i have seen some racks come out of adjustment the big nut by the p/s lines back off and creates to much gear lash..
[/align]
ORIGINAL: 92cobra
uberstang1
09-20-2015 06:42 PM
09-08-2015 11:50 AM
