Driveshaft swap
Driveshaft swap
im pretty sure my driveshaft is no good, alot of vibration at highway speeds, so i found a guy with an aluminum one figure why not upgrade
do i have to take down the Exhaust to do this or can i just work my way around it?
RE: Driveshaft swap
well for one before flushing good money down the toilet....if you have a vibration at highway speeds..I'd check the run out on your rims and tires for any irregularities.,.then balance if necessary..and before spending money on a driveshaft ..check any u-joints when you pull it down for binding, loosness or roughness.......and check the tailshaft bushing for wear
RE: Driveshaft swap
its only when im on the pedal once i get off the shaking continues for a second then ceases, and once i get back on the pedal it continues, so im ruleing out most of hte things and it seem sto be pointing me to the D/S which i was gonna change any way
BTW the bolts on the D/S connecting to the rearend, i dun really have to worry bout them snapping do i?
Matt's 95 Stang
10-05-2015 07:16 AM
