Carb to EFI swap
Old 02-07-2008, 06:44 PM
02GTman
02GTman's Avatar
Default Carb to EFI swap
I can get a 91GT EFI engine and everything that goes with it for $350 and it runs. How hard is the swap into an 85 carb?
02GTman is offline
Old 02-07-2008, 06:59 PM
1992gt400hp
1992gt400hp's Avatar
Default RE: Carb to EFI swap
just take off the intake and put ur carbed one on... swap the timing cover and chain out to the old style ones and you should be good 2 go
1992gt400hp is offline
Old 02-07-2008, 07:01 PM
1992gt400hp
sorry! i read that wrong... i thought you wanted to convert the EFI engine to a carbed one... my bad man. maybe sum1 else can help ya a lil bit better
Old 02-07-2008, 08:47 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: 1992gt400hp
no swap of timing cover is necessary....just remove mechanical pump and buy a block off plate......you'll need the complete wire harness and swap out pick ups in fuel tank for an efi one and really need an efi tank as it'll have the baffles that surround the tank and keep fuel around the pump so slosh related drivability concerns don't occur..cause a carbed stang in 85 doesn't have a baffle in the tank....you'll also need to wire in a set up to run the elec pump..in short it'll be a project.. there are alot of little details I'm leaving out too..just to much to list.. my advice.. stay carbed and buy a efi car
mjr46 is offline
bradleyb
11-27-2015 07:50 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Carb to EFI swap
