AFR 185
RE: AFR 185
ORIGINAL: mjr46
you most likely will be fine.. but either way it's always a good idea to clay the piston and check your clearance.....look at it this way....would you want to ruin a expensive set of heads from the get go??
RE: AFR 185
ORIGINAL: nmerrill
Come on.. you can be like me and not check PTV clearance, nwo im having to have all 8 exhaust valves repalced.
ORIGINAL: mjr46
